Posts: 977 Likes: 7
Posts: 977 Likes: 7 |
While reading through some of the literature that I have accumulated over the past few years, I came across this March 1934 issue of a Canadian GM Service News Review. I found the instructions on drilling a vent hole in the transmission cover to prevent a buildup of pressure in the transmission and subsequent leaks at the rear wheel bearings interesting. ![[Linked Image from i1302.photobucket.com]](http://i1302.photobucket.com/albums/ag125/wem50/Photo035_zpstopnjg03.jpg)
Bill Masters
Posts: 1,478 |
Wow! That is really something!
Posts: 119 |
That is some incredible info. Thanks a lot Bill for thinking of others.
1936 Chevy Std 1954 3600 Truck 2008 Corvette Z06
Posts: 977 Likes: 7
You are welcome, oldchevy.
Bill Masters
Posts: 825 |
hi there, to be sure that we are talking about the same part in your article, the transmission cover is meaning the part where the gearstick come through and that is where the relief hole should be drilled? Ps: my transmission leaks so much at the speedo cable connection, do you think that mine has natural ventilation built in? Peter
never give 100% unless you are giving blood.
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
It will only vent if there is no oil there to seal it. As long as it is leaking the oil is sealing the escape route. With the vent hole up into the shift lever housing (cover) there should be little if any oil present so the air/pressure will escape. With a "new" vent hole in the housing it may help to reduce the oil leak but it should probably be sealed at the cable in a more efficient manner.
Posts: 1,381 |
Good luck with that! Mine has dripped forever and ever and then some more. I've tried several remedies. No luck. I like the vent hole though.
Posts: 977 Likes: 7
Yes, blueyAU, the transmission cover referenced in the article is the part to which the gear shift lever attaches.
Bill Masters
Posts: 977 Likes: 7
I made a gasket from thin rubber and placed it where the speedometer cable outer housing's bell mouth meets the threaded fitting at the transmission. It seems to work.
Bill Masters
Posts: 1,478 |
Sounds like a good idea to me.
Posts: 414 Likes: 8
Posts: 414 Likes: 8 |
How big a hole do you need? Is there any particular place in the cover to drill the hole?
Posts: 1,381 |
