#356284 11/18/15 04:39 PM
Carlyle Offline OP
Is there a non standard cleaner available to clean stained whitewalls on tires that have been wrapped and in storage for many years? Carlyle
Generally the stain is deep into the white rubber and can not be removed.
Wesley's Bleach White is what I use. If that dosen't help nothing will (that will not harm the rubber)
I use a white wall cleaner from Coker tire. Works pretty good
If Wesley's Bleach White doesn't work use an SOS pad and hot water. I have used SOS pads many times and they work great!
Thars what I used when I was a kid and there were no commercial W.W. cleaners.
I had white walls on my OX cart. dance
Be aware of the possible/probable breakdown in tires, after many years of existence.
I use Wesley's Bleach White but the SOS pads work on really stubborn stains. Never used anything on my ox cart....it had wooden wheels! drink
Ed
I've used SOS pads since the 60's and would recommend them, too. Even used to use them on red-line tires.
leagl #356339 11/19/15 12:45 AM
I have used SOS pads forever and they work on just about anything! Because the SOS pads work so well on tires I haven't used tire cleaner in several decades.
Hi,
Would someone explain what a SOS pad is please?
Brian
An SOS pad is a small pad that looks like steel wool and it is impregnated with lots of soap. When the SOS pad is dipped in water the soap is activated and the pad is used for scrubbing pots and pans and lots of other stuff. SOS pads have been around for many decades.
Go to your local grocery store, look in the area were they sell cleaners and etc. and you will see a box that says "SOS". There are multiple SOS pads that come in the box.
Great answer Chevgene
SOS means....Save
Our Saucepans
I have to hide them from my wife!!!they destroy the non-stick pans!!!
The SOS pads are very fine 00 steel wool. More coarse steel wool or a wire or brass brush shold not be used as the dig into the rubber. I use a plastic bristol vegtable brush along with the Westlys.
Just to clarify, the SOS pad is unrelated to the stuff they used to serve us in the Army.
The S--- on a shingle maybe would have cleaned the white walls better. patriot
If the S--- on a shingle did not clean your whitewalls, you know it cleaned out your intestinal tract. dance
[quote=chef-chevy]SOS means....Save
Our Saucepans
That's what the SOS means when using them in the house. It means Scrub Our Sh!+ out in the garage.
Don't forget our friend the Brillo Pad
[Linked Image from i563.photobucket.com]
Thank you for the reply! Believe it or not they call them here "steel wool soap pads" and that's what I use 😜
Brian
Carlyle Offline OP
Thank you all for your suggestions. Carlyle
Who would have guessed knowing what a sos pad was would make you feel old.
Wake up to learn something new everyday.
oboy #357084 11/30/15 05:50 PM
Just looking in the mirror, each A.M., makes me feel old! dance
"Oil Eater" works better than most WW cleaners.
Dick
I hear you! hello2 hood
Ed
