Posts: 327 |
Have finally decided to attack chronic oil leak coming from rear of engine. Questions: is there a torque recommendation for the rear main, and where might I find some "keeper plates" that lock the main bolts by bending up the tabs. Jim
Torque to about 85 foot pounds. No figures were given back then.
Bolt locks are scarce so try to save yours. They switched to lock washers in the later years and they work well slso.
Posts: 558 |
My old 1932-1935 Chilton's repair manual says 80-85 ft. lbs.....
Mac
Posts: 2,262 Likes: 6
Posts: 2,262 Likes: 6 |
If you prefer to stick with using the keepers with bend-over tabs, they are pretty easy to fabricate from sheet metal.
Good luck with your project!
All the Best, Chip
"It's wise to choose a SIX"
Posts: 327 |
Thanks guys, now on with the show. Jim
