Posts: 549 |
"Frame Off" restoration, its a journey not a destination
Posts: 544 |
Beautiful color!! Thanks for sharing!! Good luck with it and don't forget to show the progress!
"Take a stand and make a mark" Gilbert Kent
Posts: 3,620 Likes: 5
Posts: 3,620 Likes: 5 |
Looking great! It's nice when all the new shiny stuff starts to happen!
Posts: 3,578 |
Is that masked stainless trim that has been left on behind the rear door, or is it stamped into the body?
Posts: 350 |
Boy can I relate...It looks great! Congratulations.
Thats how the bodies were stamped. Would not have had that much shine with the original lacquer UNTIL the paint was buffed out and polished. Looks grate and a good color match.That was a very popular color in 1951.
Posts: 2,142 Likes: 3
Posts: 2,142 Likes: 3 |
It looks great! The worst part of it is that there still a lot of work to do. The fit and finish seems to take forever and it is just so hard to keep from rushing it. The best part of it is everything you do from now on give you the feel of progress
John
Posts: 549 |
It is foil, the whole car is covered in it, plus I have sound deadening material for the inside of the doors yet.
Posts: 549 |
Yes my buddy calls it a "modern paint job", color Fathom Green, 4 coats of primer, 2 coats of primer sealer, 3 coats of paint, and 3 coats of clear. So basically the car is a 1/4 inch bigger
Posts: 2 |
That is beautiful!
I fell in love with the Fleetline model as a young teenager in the early 1970s. A local gas station owner proudly displayed his 1950 Fleetline in front of the station; it too was green metallic, but maybe a shade darker. For 1950, I guess this would have been "Crystal Green."
I have owned my 1949 2 dr Fleetline since 1988--it is black, but looks very elegant.
Congrats on getting your car this far along!
-Mark
Posts: 1,113 Likes: 1
Posts: 1,113 Likes: 1 |
Sweet color!! Mine's next!! LOL
Rick
Sweet color!! Mine's next!! LOL You're starting to fall behind!
Posts: 4,951 |
Looks great dads 51. Ours are "different" 1951's - but everybody in VCCA is going to love yours!
Posts: 114 |
Yes my buddy calls it a "modern paint job", color Fathom Green, 4 coats of primer, 2 coats of primer sealer, 3 coats of paint, and 3 coats of clear. So basically the car is a 1/4 inch bigger Not entirely an exaggeration, either! From my own experience, I can tell you one thing specifically to beware of: do you remember the sliding lock plates that retain the exterior door handles to the doors? They will be significantly more difficult to insert than they were to remove. Both the additional paint thickness above that of the old lacquer, and the new uncompressed rubber pads can conspire to make reinstalling the exterior door handles lots of fun!
Scott Andrews Dacula, GA #J25833
Posts: 3,801 Likes: 1
Posts: 3,801 Likes: 1 |
Posts: 6 |
WOW ! Thats all I can say right now.
Posts: 549 |
Well safe at home in the Man cave! I'm thinking front and rear glass first?? and then work my way out? ![[Linked Image from i1027.photobucket.com]](http://i1027.photobucket.com/albums/y336/nonidrinkers/IMG_7764_1.jpg)
Posts: 549 |
Not sure if I should start another subject or just add to this as I'm guessing I'll have a bunch of questions as this re assembly goes on. This one is what color was this top bar that I have primed lime green for now. I'm guessing semi gloss black? Or argent silver? ![[Linked Image from i1027.photobucket.com]](http://i1027.photobucket.com/albums/y336/nonidrinkers/90f4e9417bbc56f1df65b98268ff3299.jpg) ![[Linked Image from i1027.photobucket.com]](http://i1027.photobucket.com/albums/y336/nonidrinkers/226f382d1d5fd82d5e2e5a00db7dd50e.jpg)
Posts: 549 |
Which rubber bumper is correct? The one with the pointed nipple seems right but doesn't give with the hole size and won't reach through? The other one is going to need a bolt and washer? ![[Linked Image from i1027.photobucket.com]](http://i1027.photobucket.com/albums/y336/nonidrinkers/9bce09ea4a9ce3a24e10f0d2c4e3d351.jpg) ![[Linked Image from i1027.photobucket.com]](http://i1027.photobucket.com/albums/y336/nonidrinkers/613c391368f6a9e5a27f133c280ec645.jpg)
The fasten with the nipple. My '50 has two thicker bumpers and two thinner ones. It looks as if the two pieces of metal are too far apart.
Posts: 549 |
Are the two thinner ones on the outside or towards the inside? Thanks
