#35583 07/17/04 07:00 PM
RJS Offline OP
chevy I have a problem with my 1952 Chevy Deluxe Harmonic Balancer and the water pump pulley. Does anyone know where I can obtain a harmonic balancer, crankshaft seal, and a 1/2" water pump pulley? If they make them NOS, I would prefer that, however, if they make them new, that would work as well. I have tried some local junk yards in SE CT with no luck. I would appreciate any help? chevy
#35584 07/17/04 07:26 PM
Hi, RJS,
It would help if we knew what the problem is. Have you ruined the harmonic balancer or does it have a grove cut in it? The seal is no problem and available numerous places. The water pump, when rebuilt, comes with the pulley on it.
A bit more info and we will tackle the problem for you.
Agrin
#35585 07/18/04 09:44 AM
A 52 chevy does not use a 1/2 inch wide belt, that started in 53.
#35586 07/18/04 03:00 PM
52 passenger car has 5/8 inch pulley and 53 passenger has 3/8" wide pulley.
41-52 all w/216 crankshaft pulley
39-52 ALL, 53-54 UTILITY, have the same pulley for the water pump fan.
Water pumps with fan pulley 41-52 ALL and 53-54 Utility (exc. 261)
Walt D
1934 Mstr 4 dr/sidemnts
1937 1/2 ton P/U
1953 Bel Air HT
1946 Aeronca 7-AC Champ
#35587 08/23/04 04:42 PM
did you ever get all your problems solved with you crank and water pump pulley,s. i just joined the forum and am street rodding a 52 hardtop. i have all the original running gear for it. nagle5
cheapskate 52
#35588 02/27/05 09:25 PM
RJS Offline OP
Yes, I found a harmonic balancer and all the necessary hardware. My generator had a 1/2" pulley, so I went to an auto electric shop ans they put the right pulley on it. I came from a 1952 truck. I installed everything and it all works well.
