#355701 11/09/15 04:08 PM
6wheel Offline OP
Another problem with this 55 show car I just bought is the brakes. The pedal has lots of free travel before engaging. I thought I'd solved it when I filled up the master cylinder, and when I adjusted the brakes, and when I bled the brakes. But the pedal still has too much free play. Is there an adjustment to the pedal itself? I bought a new Malibu in '72 that had the same problem. The dealer argued with me that it was normal, but when I insisted they fixed it. Unfortunately, I don't know what they did. Any thoughts?
Sid
What does your shop manual indicate?
How many notches did you back off the adjusters?
I adjust (tighten) the brakes to the point where it is difficult to turn the wheel (this centers the shoes) then I back off till you just hear and not feel the drag.
as i recall, the push rod between the brake pedal and the master cylinder is adjustable and if so, simply lengthen it. mike
6wheel Offline OP
The Dog was right. Its covered in the manual. I didn't think it would be there, so I didn't look earlier. As Mike indicated there is an adjustment on the rod to the master cylinder. Unfortunately, it's adjusted to the maximum length. so I'll find a longer rod, lengthen this one, or make a longer "U" connector (the piece from the brake pedal assembly that attaches to the rod). I'll also re-check the brake adjustment.
Thanks guys,
Sid
Always look in your shop manual first because most of the time it will contain the information that you require.
