Take a look on the side of the lock mechanism and you will find the location of a very short pin* that captures the lock cylinder. This pin must be removed to allow the cylinder to come out the end of the housing. There are two types of lock cylinders. One has a single sided key and the other has the double sided key. *Be careful and don't drill into the cylinder as that ruins it.
