#35446 05/02/04 06:00 PM
I have a 49' 1/2 ton and my oil pan is leaking. I was wondering is it possible to drop the oil pan while the engine is in the car so i can fix the leak?
-Justin
#35447 05/02/04 10:43 PM
Yes- Its a very easy oil pan to remove.
#35448 05/03/04 12:27 PM
Do you know where the VIN# is located on a 1950 1/2 ton pickup?
#35449 05/03/04 06:35 PM
thanks for your help.
#35450 05/03/04 07:12 PM
Cannot emphasize enough that you spend $25 bucks or so and pick up a shop manual. When removing the pan from the 216 there are some oil troughs that have to be maintained in proper alignment.
