Posts: 3,578 |
I would have thought correctness for the 48 generator would have been a slam dunk...To answer your statement,not all of us are perfectionists...I get a charge out of getting it right!!! p.s. where can I find the locking key for my nut?
Posts: 1,743 Likes: 11
Posts: 1,743 Likes: 11 |
Confused, the lock washer or the key to the pulley/shaft? I would think your local parts store. Don't know if it is special.
Have you thought any about calling Mr. Geear, the tech.
When you get a chance, send me a picture of the rear end of you gen. Straight on from the back. Please?
I sent Uncle Ed a e-mail asking his thoughts and post here.
Dale has a high points car, wish he would check-in!
Posts: 3,578 |
The key,my PC is down so communication has been a challenge
Posts: 129 |
Pictured below is from a brochure from the Van Nuys assembly plant in Los Angeles California. The generator pulley clearly shows to be natural possibly zinc/cad plated. The front and back plates appear to be lighter in color but I am not definite because of lighting. When restoring my car I took note of all these details and that is how I arrived at my version of restoration for 1948 Chevrolets. Now I’m not perfect by any means but I think I am pretty close. One thing I noticed on unrestored generators is that the front and back plates usually were nature in color and some had a hint of some black paint, depending on how well they were preserved/stored. I think, they were possibly painted along with the generator body but the paint didn’t adhere very well to these pieces. With time and usage the paint came off. This is just my theory. I will start a new topic posting up two pictures showing the engine in more detail that I am sure will blow up into many more interesting discussions because it answers the coil bracket color and position question and much more. Russel as far as my generator tag, thanks for the info and it is duly noted. I have always taken the approach that to have an earlier correct part is better than a later correct part and/or a incorrect part all together. Because it is hard to find a generator with an original tag none the less with the correct part number I didn’t mind the date being earlier, why because in 1948 the generator would have be available vs a generator with a later date code on the tag. Because a generator with a later date code was not made yet, it’s in the future. As a lead VCCA judge in this category I would never deduct for a date code that is earlier with correct part number. I hope all of you continue to have these great discussions, we are all learning and documenting for future generations!!!
Posts: 3,578 |
Excellent info Johnny...I can not wait to see what you are bring to the table next Both my generator have this tag...40-48 per the parts book
One thing I noticed on unrestored generators is that the front and back plates usually were nature in color and some had a hint of some black paint, depending on how well they were preserved/stored. I think, they were possibly painted along with the generator body but the paint didn’t adhere very well to these pieces. With time and usage the paint came off. This is just my theory. And a darn good one too! At least that is my theory also. Appears the front nut and washer were painted in place on the generator also. I hope all of you continue to have these great discussions, we are all learning and documenting for future generations!!! A-MEN to that. That in itself is the reason I drag some of these discussions out for soooo long. Just trying to get the info as correct as possible. AND...let me say one more time, you have done an outstanding job with the contributions you have made to the "47's and '48's Chevrolets.
Yes, but the serial number, make no sense????? Should be a number 0 to 9 and then a single letter and the a number from 1 to 31. The date code. At least that is what I understand for Chevrolets
Posts: 1,069 Likes: 9
Posts: 1,069 Likes: 9 |
Just looked at the generator on the 47 engine I have. Pulley is painted black. Gen # 1102767. Don not have the history on this engine. Pulled the engine out of a coupe I bought a few years ago for the front seat. The number tag was black. Looked at my 48 and the pulley isn't painted looks just like the generator fan. Kind of rusty but not bad. The generator is a rebuilt without any numbers I can read from the top anyway. Bet the number was 1102667 will have to check tomorrow.
Posts: 3,578 |
Thanks for chiming in Keith
Posts: 6,689 Likes: 21
Posts: 6,689 Likes: 21 |
CC, I suggest the following: a. Remove your generator. b. Take the nut, washer and pulley off. c. Take the front and rear plates off. d. Take the band off. Now as this thread changes as to the colors quickly paint or don't paint the parts as information becomes available. That way when the final finally is finally reached you can quickly reassemble all the parts and re-install your generator. You will be the first one in the country to have correctly painted generator. Oh glory , what a thrill that will be to say nothing of the bragging rights! All the other cars besides the Fleetlines are not that sensitive and will operate just fine any way their generators are painted. It is you lofty-minded Fleetliners who insist on being perfect. I hope you take my suggestion at heart: Staying awake at night worrying whether that Little darling fleet-line has the correctly painted generator can be annoying and lead to sleep depravation. I sometimes worry about you. Charlie
Posts: 1,774 Likes: 4
Posts: 1,774 Likes: 4 |
Dale has a high points car, wish he would check-in! Sorry Russell I haven't had time to check my '48 generator yet but I suspect that on that old of a car with 72+++ miles it has probably had a rebuilt generator put on it. I will try and check it if I can remember!
Ed
Posts: 3,578 |
Charlie, sleep will never be a problem for me, I work 12-14 hour a day...Yes as I mentioned before, I tend to be an over achiever. I can only guess there is lots like me in this club, not just us Fleetliners
