#353682 10/11/15 03:54 PM
SvMo Offline OP
I have a Chev Master 4 door Sedan, 1938. I think the gear shift lever in my car is not the original. Does anybody has a picture on how the original does look like? I have not been able to find such a picture on www. Are anybody selling a reproduction of it? It seems Chevs of the 40s and Fillingst are not.
This knob isn't OEM but the lever is.
SvMo Offline OP
Thanks. Seems like the lever is brown/black? Then for sure my lever is not the original one, as it is crome and with a cromee knob!
Did the know has this brown color in 1938? I see Chevs of th 40s is selling this for knob for 1929-1939: https://www.chevsofthe40s.com/detail/11568/Chevrolet_Shift_Knob_All_With_Floor_Shift_Black.html
But maybe it did not look the same all this years and was not black and had this shape in 1938?
SvMo Offline OP
Hi,
By the way: Do you have a detailed picture on how the emergency brake lever is connected to the emergencey brake knob? Also my knob-part is not original, as it is a crome part connected to the lever.
You need to ask them if it's a push on or thread on knob. The OEM knob was a push on. The original color of the shifter is Plover Beige, the same as the lower part of the dash. Many years of wear & weathering later it looks the way it does now.
Chevs of The 40's application is incorrect. The gear shift knob for 1929-32 is threaded and it is not the same as the gearshift knob for 1938. Also, the gear shift knob for 1929 and 1930 is a two-piece knob.
