#353661 10/11/15 09:47 AM
Genem Offline OP
After having some battery issues not holding a charge I replaced the battery and all was ok. As a habit I always disconnect the battery when not in use. I hooked up the battery and opened the hood and noticed that the regulator on top of the generator was glowing and started to smoke. I disconnected the wire from the regulator. Assuming a dead short I inspected the wire from the generator to the amp gauge and all seemed ok but upon just touching the wire to the Reg brought smoke and sparks. I removed the regulator opened it up and all seems ok. My next step will be to connect the Reg and gauge by an exterior wire and see if it works. Or is this just a bad regulator?
Genem #353663 10/11/15 10:05 AM
When asking questions always give us the year of car that you are working on. Anyway, a voltage requlator was not used on the generator. The item that sits on top of the generator is a cut-out relay and it is just basically an off-on switch for the generator. When the points on the cut-out are open it prevents the battery voltage from running back through the generator. When the points are closed (car running) that allows the generator voltage to go to the battery.
From what you describe, it sounds like possibly the points on the generator cut-out are stuck closed. If so, and with the car not running, that will allow the battery voltage to run back to the generator. Having no place to go the battery voltage will make the generator and the cut-out hot, and it will tend to melt the solder on the armature in the generator. Pull the cover off of the cut-out on top of the generator and look at the points. If the points are closed you found your problem. If that is the issue then you will need another cut-out or you will need to convert your cut-out to solid state by installing a diode.
If the points are not closed then, as a test, you can replace the cut-out and see if that cures the problem. If it does fix the issue then you have a defective cut-out.
Also, check the cover on the cut-out to make sure that it is not touching either the battery terminal or the generator terminal on the cut-out. If it is touching either terminal that would cause a direct short.
Junkyard Dog #353670 10/11/15 11:20 AM
Genem Offline OP
Thanks Dog, you always come to my rescue, and for your info it is a 30 SC
Genem #353671 10/11/15 11:33 AM
Always glad to help out.
Junkyard Dog #353675 10/11/15 01:30 PM
Genem Offline OP
Right on dog. Terminal hitting inside of case
Easy fix
Genem #353680 10/11/15 03:08 PM
Yep, that is a typical problem on some of the cut-outs. Hopefully no damage was done to the cut-out or the generator.
