Posts: 59 |
Does anyone know how too disassemble locking assembly on door handle so I can have them replayed??
Posts: 3,163 |
There is a roll pin on the side of the shank that you can drive out. You then need the key in the key hole to keep the wafers from falling out then you pull the barrel & shaft. There is the square piece at the bottom that will come out also....Joe
Posts: 59 |
Thanks for the help It came right apart as you said Thanks
