#352585 09/26/15 11:40 AM
Ph1l Offline OP
Hello, can any tell me how to remove the balancer from the front crank pulley.the Chevrolet manual says to use a puller but shurely its not just pressed on is it?is there no bolt into the crankshaft the book I have is only the Chevrolet repair manual showing shortcuts and methods for Chevrolet six cylinder cars and trucks.have they left something out.thanks.Phil.
Ph1l #352588 09/26/15 12:40 PM
Yes you need a puller! It is a light tap fit on the crank.
Ph1l #352631 09/27/15 01:32 AM
Yes, the Harmonic Balancer is pressed on to the crankshaft.
Ph1l Offline OP
Thanks can't believe it's an interference fit with the crank going at speed,just a thought, you use puller for taking off what about back on.I've read on the internet that you use a certain puller then you use another piece of the kit to press back on but there's no pictures to help me get it into my head I just can't see what would help to press against to make the pulley go fully home.engine is out of the car.thank you for all your help everyone.Phil.
Ph1l #352640 09/27/15 08:29 AM
The force fit and key will hold the balancer in position. Most of us use a piece of pipe or wooden block to encourage the balancer into position.
Ph1l #352641 09/27/15 08:41 AM
Hello Ph1l,
From what I have read, it appears that the part on the end of the crankshaft used to receive an engine hand crank is used during installation of the harmonic balancer. My reference book mentions that one of the puller tools called the 'driver head', is placed in the starting crank jaws. I assume that it turns the hand crank jaws into a tool to drive the balancer onto the crankshaft. I hope that you'll be able to make sense of the written discriptions given in the reference books. Words such as 'assemble until removed' and 'drive into position using puller screw' tend to make me think, WHAT?
