#35179 12/17/03 02:53 PM
DUDS50 Offline OP
first, thanks for all the help on the visor! Next question, does anyone know where I can get my hands on the door lock plungers ( for lack of a better term), the rods which rise from the locking mechanism inside the door up through the window sill molding and have the rubber/ plastic knobs attached to them as to lock and unlock the door? I believe the locking mechanisms inside the doors are all intact but have no pull rods. Any help would be great.
#35180 12/17/03 03:44 PM
I built my missing ones from a piece of steel wire the same diameter as the holes in the plunger caps (plastic caps that thread on after the window sill is in place).
Just put a right angle bend at one end and a slight bend half way up to match the groove in the door then thread the end that passes up through the window sill.
Hope this helps!
Andrew Jones
#35181 12/19/03 03:39 PM
Ah, what year model do you have? I'm in the process of restoring and I could take a picture of what a 54 looks like. Will this help?
Byron
#35182 12/21/03 01:02 PM
DUDS50 Offline OP
sorry for the delay in response, I have a 1950 styleline sedan deluxe.
#35183 02/03/04 04:26 AM
DuDs50,
Did the pictures make it or have you had a chance to open them....sent 'em to your email address. Would have posted them here but was unsure of a location to post.
Byron
