Posts: 3 |
What is the differance between 61 Imala and 61 belair bubble to[?
All 1961 Impala and BelAir 2 door hard tops were so called bubble tops. For 1962 the Impala at a more formal roof line and back window and the BelAir still had the 1962 bubble top.
Posts: 85 |
The exterior trim is fancier on the Impala than on the Bel Air and the Impala interior is plusher. For example, the Impala has full carpet while the Bel Air has carpet only on the transmission/drive shaft tunnel. Also, the Impala has bright aluminum trim on the instrument panel, the Bel Air instrument panel lacks this trim. If you look at the 1961 brochure on the old car brochures web site http://www.oldcarbrochures.com/, you can see excellent exterior illustrations for both models.
Posts: 3 |
Wow thanks Have a 61 impala bubble top info helps.Another question,did the Impala have a molding on the exterior rocker panel. Have found photos with and without? Was it only with ss models?
The rocker mouldings were a dealer installed accessory.
Posts: 2,142 Likes: 3
Posts: 2,142 Likes: 3 |
The rocker mouldings were a dealer installed accessory. You might want to check that, I am pretty sure that in 1961 there were no accessory rocker mouldings offered as an accessory, however they were standard on the Biscayne, and those were just a small thin strip. It has becomerather common for people to install the 62 Impala rocker mouldings on 61's
John
1961 Custom Features price schedule Moulding, body sill, Accy. # 986356, All pasenger cars and wagons, $11.85.
Have you ever seen a set? What is the group #?
John
Yes, I have a set. They are in the Accessory Group.
They are in the Accessory Group.  Specific group # ?
John
The came packed three sets to a carton. They would be in the rocker moulding group in the 1961 parts book as well as the accessory lisings. Being an accssory they would have been dscontinued at the end of the year. The were of the "wide" type.
Gene I have a 1961 specific parts book printed 9/60 and I can not find a listing, I must be missing something
John
The Biscayne came with a narrow moulding as standard equipment. The accessory moulding covered almost the entire rocker panel ( top to bottom). They were seldom seen on anything but an Impala.
1961 Custom Features price schedule Moulding, body sill, Accy. # 986356, All pasenger cars and wagons, $11.85. Interesting that the part number would be lower then the part number for the 59 and 60 rocker panel mouldings, that number is 987985 Also I made a mistake my 1961 parts and accessories catalog was printed October 1 1960, not 9/60
John
I just found it the reason and found the group number 8.304 and is listed in Group 8.000 sheet metal. The part number must have been misread the number in the book is 988356, so it is higher then the 59/60 units. I guess the "8" looked like a "6"
John
Often GM accessory numbers would begin with 986 and go up from there. Then they would drop down to 985 and 986 and go up. They never duplicated numbers though.
Often GM accessory numbers would begin with 986 and go up from there. Then they would drop down to 985 and 986 and go up. They never duplicated numbers though. That's not the case here, you just misread the part number, easy to mistake to make
John
Posts: 85 |
I have a 1961 Custom Features Catalog. It doesn't list the group numbers but it shows the part number as 988356. Here's the catalog's description for the part: "The moldings are attached to the rocker panels below the door openings and cover a most vulnerable part of a car. The stainless steel moldings are polished to a bright finish and will resist rust, corrosion and protect the paint on the rocker panel from stone chipping and abrasion. The moldings are not standard equipment on any of the 1961 models. Three part numbers are packaged to a carton."
There's a drawing of the molding, it looks like it's about two inches wide. It looks wider than the Biscayne molding.
The catalog is copyright 1960, it doesn't indicate which month they published it in.
Yes, they were much wider than the skinny Biscane moulding. If they did all of those things you would have thought they would have came standard on an Impala at least. They did in 1962.
Posts: 85 |
For fun I looked at the Impala and Bel Air illustrations in the 1961 Dealer Album and none of cars were depicted with the optional rocker panel moldings.
I don't recall ever seeing a '61 Chevy with those moldings. I owned a 1961 Impala 4-door sedan that didn't have them. My Bel Air Sport Sedan doesn't have them either.
Posts: 3 |
Back in 68 I had a 61 bubble top back then I kind of remember kick panel moldings on some cars. That's why I'm asking .Just bought a set for a 62 which should fit my 61.
Posts: 295 |
I don't recall ever seeing a '61 Chevy with those moldings. I owned a 1961 Impala 4-door sedan that didn't have them. My Bel Air Sport Sedan doesn't have them either. Yep, as has been stated before, those wide rocker moldings were an accessory only, never factory installed. Only the Biscayne and Brookwood had the slender ones factory installed. You also see a LOT of '63s and '64s with the '62 rocker moldings installed, which is wrong of course. Verne
Verne Hey Verne, For the life of me I can not recall ever seeing a 61 with those mouldings, or even a car in some of those prolific PA junk yards that even had remnants of ever having them. Did you recall seeing any? I did see a few 60's that had the remains of some rocker mouldings, but no 61's.... I went digging skimming through all the old LGC magazines, (those were the days) not even a photo of one or any for sale in the classifieds, Not common at all, to the point that I never realized that they were offered, just never seen. NYChevyII pointed out to me (privately) that there was an 58-64 Impala poster and Floyd Garret's 61 pictured in the poster has a set on. I personally don't think that the 61's wear the rocker mouldings well, I am sure I am not the only one, besides being the first place to kick your feet to knock the snow off your shoes before getting in the car might have not helped the popularity. They probably look to good after one winter
John
