#351251 09/10/15 01:54 PM
Is it normal for a 32 to have some play in the steering?
323window #351260 09/10/15 03:25 PM
Unless the steering column has been rebuilt it is common for some play.
323window #351272 09/10/15 05:22 PM
You should have around 1/2" backlash in each direction when the wheel is turned to the left and then to the right. If you have a lot more than that then the steering box should be adjusted. If the adjustment doesn't cure the problem then it is time for a rebuild.
