#35082 11/13/03 04:23 PM
krnut Offline OP
I have a 53 chev pickup with a 216 in it.Is it possible to switch to a 51 235 from a car or a 235 from a 55 suberban?. Will the front mount from the 216 adapt to the 235 engine? the car engine has side mounts and the 55 engine has a different type of front mount setup from the eway it looks. Are the front covers interchangable to allow a swap? thanks krnut
krnut
#35083 11/14/03 09:24 AM
Jim Offline
Jim
41 Special Deluxe
48 AD 1/2 ton
52 Suburban
69 Nova Coupe
63 Nova Convertible (daily driver)
#35084 11/14/03 12:16 PM
If you are lucky the front mount plate will still be in place, it may be necessary to drill the frame and or the plate but it will work.
#35085 11/15/03 05:52 PM
krnut Offline OP
thanks for the help. now i can go ahead with my project. krnut
krnut
