#350796 09/05/15 04:57 PM
doneast Offline OP
33 Eagle bell housing 836967 or 836867 poor casting on numbers
33 Eagle transmission CM85554
Double checking to see if these are the correct numbers now that everything is apart.
Thanks Don
Looks like the bell housing should be a 837275. Fits CA DA. I'll look but I probably don't have another one
836397 fits 1931
836795 is 31/32 exc. AE
I don't see the trans number. Is that a stamp number or a casting number? Should have free wheeling.
....Joe
1931 Sedan Delivery 31570
1968 Z/28 Camaro
1969 SS 396 Camaro
doneast Offline OP
The transmission number is stamped on a smooth place just behind the shifter rod.
Don
There will be a casting number on the side of the case & a date code...Joe
1968 Z/28 Camaro
1969 SS 396 Camaro
doneast Offline OP
Side of cast 3 590532
3
where do you find these numbers?
Don
CM 00001 to CM 71810 were produced from September, 1932 to January 1, 1933 some time after that they ended the CM numbers and began with CN25701 on February 1, 1933. So looks like you have a correct transmission.
doneast Offline OP
Clipper, thanks for information on transmission. Do you have any information on the bellhousing #836967
Thanks Don
Don check the actual cast date on your clutch housing as I cant find that casting number either, See pictures with casting date in Members pictures forum.
https://vccachat.org/ubbthreads.php/galleries/350832/1933_clutch_housing_casting_Da#comments
JACK
