Posts: 17 |
I recently purchased a 1925 Chevy Superior Series V. The gas tank has holes in the end caps that are 1/4" x 1/2". I would like to find a new replacement or find the best way to restore it to last many more years.So if anybody knows of a company that makes reproduction tanks for that car or best way to refurbish it to last many many more years. Bill
Posts: 2,262 Likes: 6
Posts: 2,262 Likes: 6 |
Hi Bill --
Tanks for most of the old Chevys of this vintage are pretty scarce, and nobody (as far as I know) is producing authentic reproductions.
It is possible for a good body & fender guy to piece in replacement pieces in your tank. Then you have to completely clean the tank (radiator repair places can boil it out with chemicals for you), seal it with special sealers, paint the outside and reinstall. Of course you can't be sure there aren't other areas about to rust through.
A better option might be to find a solid used one. They occasionally come up on ebay and you should also post in the "Parts Wanted" "1912-1928" forums here.
There have been lots of discussions on the topic here on Chevy Chatter. Just use the "Search" button at the top of the page and you can find them.
Hope that helps.
All the Best, Chip
"It's wise to choose a SIX"
Posts: 4 |
I know a shop here in the Tampa Bay area that will build your tank to exact specifications. I wanted the same thing, but the price was $800. Stainless was a lot more. Needless to say I couldn't afford it, but I believe the shop is still available and I'm quit sure it will be done right. It's called Dunrite Metal Fabricators 12099 44th Street North, Clearwater,FL 33762. (727) 299-9242 Redbird
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
There are some shops that can make almost any sheet metal part you need, however if you need to ask the price then chances are you will not be able to afford it.
Posts: 3,008 Likes: 1
Posts: 3,008 Likes: 1 |
I was working on a friends 1928 Fire Truck several years ago. I took the gas tank to a local radiator shop. They cut the ends our and welded new ends in. It looked almost original when finished. Might be worth a try.
Joined VCCA June 1, 1961
Posts: 17 |
I have found a very good used that has very little rust and at a fair price. Thanks for all your help. Bill
