#350063 08/26/15 01:25 PM
Ph1l Offline OP
Hya,when I took the engine out of the 31 independence I noticed the engine mount/bracket was straight onto the chassis is it right there is no rubber in between,just metal to metal?
Ph1l #350065 08/26/15 01:57 PM
Yes, that's correct. Chevy did not have any sort of resilient engine mountings until 1932.
All the Best, Chip
"It's wise to choose a SIX"
Chip #350067 08/26/15 02:11 PM
Ph1l Offline OP
Hi Chip,would you put something there or just leave it.Phil.
Ph1l #350076 08/26/15 04:36 PM
Leave it as it came from the factory.
Ph1l #350078 08/26/15 06:13 PM
I tried rubber pieces between engine and frame many years ago. Took them out as they made vibrations 10 times worse. Bolt solid to the frame!
Chipper #350081 08/26/15 06:50 PM
I have found the same to be true as well.
What they said......... iagree
