#349818 08/22/15 08:49 PM
daves30 Offline OP
working on a 1930 set of wire wheels. they have been sand blasted and are pitted. Any suggestions for filling in the pits. one person suggested using "CRE" a paint/rustproofing application in two or three coats. paint then sand, paint then sand.
Thanks David
Jmm Offline
It depends if it's structural. Tig or mig weld grind smooth where required. Use epoxy 2 part primer. If powder coating a special filler is required because of baking process. I beadblasted then applied 2k epoxy, then slick sand sprayable body filler for cosmetic pitting repairs. Sanded, applied a reduced epoxy as sealer, then single stage urethane. Then wet sand, Polish, and buff.
Jmm #350147 08/27/15 08:04 PM
daves30 Offline OP
thank you appreciate the assistance
Jmm Offline
A lot of folks powder coat the wire wheels. Outsourced.
Jmm #350155 08/27/15 08:44 PM
daves30 Offline OP
thanks power coat was one of the suggestions.
Jmm #353118 10/03/15 02:19 PM
daves30 Offline OP
thank you
the wheels were bead blasted and the paint shop who is assisting with the work has me filling the pits with metal glaze 416, than sand and refill (should see my nails).
