#349443 08/16/15 09:09 AM
Genem Offline OP
Is there anyway to test a 6 volt coil off the car?
Genem #349445 08/16/15 10:30 AM
The coil can be tested off the car with a special coil tester.
Junkyard Dog #349466 08/16/15 06:57 PM
You can also test it easily with some jumper wires (not cables), on the bench. You need a spark plug, the coil, jumper wires, and a battery.
Agrin devil
Former ChatMaster
ChatMaster - 5,000
Former ChatMaster
ChatMaster - 5,000
On a 31-32 coil, are the windings count the same? It seems that I heard that somewhere.
In other words, does it make any difference which terminal is + or -?
Bill Barker #349514 08/17/15 01:53 PM
Bill, I could never tell the difference. I purchased a tester at a National Model A Meet that would tell you if it was connected to the correct terminal. As I remember there were two lights. If they both came on while the engine was running you were correct.
Joined VCCA June 1, 1961
