I'm trying to salvage a 30 roadster that was rear ended. I have most of the broken wood from the seat back to use for patterns. I need some pictures of the rear wood structure and the metal brackets. If someone has done a 29 or 30 I would buy your construction pictures. I'm also in need of the metal brackets that mount on the sill plate. Closed body might be the same. Thanks for any help.
Dick
