Gus, in addition to what Jim has suggested, you may want to consider the following{
a. A new gasket may have come with your new pump. If not, just get some gasket material and with a small ball-peen hammer it is easy to tap out a new one. Just cut the material the same as the old one and then use the ball-peen to cut out the holes for water flow and the bolts and the edges. Piece of cake.
b. If your hoses are in good shape, just clean the inside surfaces and before putting them back on, coat them with a thin bit of Indian Head shellac.
c. Tighten the fan belt to where it is stiff but with a little bend when you press your hand against it. (with it not running)
d. Save the old pump for a core or maybe a new repair kit. I have never done the kit thing but I don't see where one can go wrong with it. Some have, though.
e. You don't have to take the outlet off to put the pump on. Nor do you have to take the radiator out. Taking the fan off will make the exchange a little more easier, though. Just four small bolts (7/16 I think) and you can take it off.
f. 41s are easy to work on. Thank goodness you have one.
I assume your old pump is leaking. That is almost the only reason to ever change one out. Of course, if you are doing a engine rebuild or overhaul, etc, I would install a new one.
Good luck with it. That is a mechanical job that is a lot of fun to do under good conditions. Get under some shade and a radio tuned to your favorite station, cold water handy, and get to it. Take your time. It ain't rocket science.
Charlie
