#347884 07/25/15 08:37 AM
fatnlow Offline OP
Is the coupe and 2 dr master sedan rear fenders the same ???
To clarify this does the coupe fender bolt into the side of the wheel well like the master sedan or does it bolts to the TOP of the wheel well ? My 33 master bolts to the side. Wanting to know this info so when I post my Fenders for sale I can have some information as to use specific to what vehicle
The 1933 Master rear fenders are the same for all body styles...EXCEPT... the left fender fits Town Sedan only due to tail light mounting holes which the Town Sedan does not have.
So the rears fit al Master body styles....1933 only.
according to my 1929---1940 Chevrolet parts book, the 1933 master TOWN SEDAN uses a different fender than the other 33 master series.
1933 # 370095 left
1933 # no listing right
for some reason the parts book does not list a right side fender for the 3 master series TOWN SEDAN.
So, I believe that the town sedan has the mounting bolt holes thru the top of the wheel well and all other 33 master have the mounting bolt holes thru the side.
Digging out my 1929--1934 Chevrolet parts book it shows the following for 33 master series :
rear fender right---1933 CA-----# 370088
rear fender left----1933 CA-----# 370087 "except town sedan"
rear fender right --1933 CA-----# 370096 " RIGHT HAND DRIVE"
rear fender left ---1933 CA-----# 370095 "TOWN SEDAN"
rear fender left--- 1933 CA-----# 370095 "right hand drive"
note same part number 370095 for town sedan and RHD
all above is exactly how its listed in the 29--34 parts book
mike lynch Agrin
fatnlow Offline OP
Thanks guys for the information.....
All the NOS fenders I ever had were equipped with holes for the tail light stand which could explain all the different part numbers knowing that the cars all came with only one tail light. Other than that fact all 33 Master fenders should fit all 33 Master cars....Joe
1931 Sedan Delivery 31570
1968 Z/28 Camaro
1969 SS 396 Camaro
The 1939 parts book lists a different number for the left Town Sedan fender.
For other 1933-1934 models the 1941 parts book mentions drilled and not drilled for tail light.
I would assume due to the few Town Sedans made in 1933 they had a more than amp;e supply of T.S. fender in stock.
If you have a right side fender for a 33 Master Coupe, in good condition, I will purchase it from you now. Thank You.....JIM
