Posts: 387 |
Anyone out there have a set of used tires that would fit my 1933 Chevy 5 window master coupe. It has 19" rims. They can be pretty warn and old. Just looking for some tires for my rims as I work on the car. Let me know what you have and cost. Thanks Don East
Posts: 3,163 |
Are you sure they are 19"? They should be 18"...Joe
Posts: 387 |
I measured the outside of the rims. Your are right it's probably 18.
Posts: 387 |
I just want tires that will hold air.
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
Don I was in much the same situation with my 38, only needed to hold it up to move around the garage so I used a set of wheels that suited the stud/lug pattern. Often the wrecking yards have an over abundance at reasonable price. Tony
