Posts: 71 |
Hello It's concerning the valve rocker shaft oil connector elbow for 1932 ( p/n 836294). I have one with by pass pipe 1/4 od an other with 3/16 pipe with the end slightly crimped. What part must I use? Thanks Henri
Posts: 71 |
The parts book give only the lenght of the pipe. (2 9/16 inches)
Posts: 71 |
I think that there is confusion. I speak of the short pipe that is soldered to the elbow that joins the 2 rocker arm shafts at the center and not the pipe that goes from oil distributor to valve rocker shaft elbow (3/16 O.D.x 16¾ long)
