35 truck,
Why don't you check with jaycross in Missouri on this forum? He has one of those trucks. My '36 PU has mounts at the front and rear of the engine and at the back of the trans.
There are 2 versions of the engine rear mount, solid metal and rubber insulated. It's easy to replace the rubber cushions in the engine rear mount and trans mount. The front mounts are common on ebay and fit a wide range of truck years. Here'e one on ebay right now for under $7 http://www.ebay.com/itm/Engine-Mount-Front-Center-DEA-TTPA-A2007-/161718254417?fits=Make%3AChevrolet%7CModel%3ATruck&hash=item25a728bb51.
Street rod builders are an excellent source of those and lots other items that they pull off and often discard. When I converted my '36 PU from 4.11 to 3.55 rear gears both the '37 Chevy car and '51 Chevy car rear axles that were used to make that conversion came to me from street rod builders in perfect condition for scrap iron prices.
Ray W
