I checked out the photos that you emailed to me and it appears that someone in the past has changed the original updraft manifolds on your engine to later downdraft manifolds so that a downdraft carburetor could be installed. Your car originally had an updraft carburetor, not a downdraft carburetor.
In changing the manifolds, they also changed the oil distributor to a much later oil distributor because of the rod on the side of the oil distributor for the two throttle springs. Since the throttle springs were used on the linkage for the later downdraft carburetor the oil distributor had to be changed to allow the two throttle springs for the downdraft carburetor linkage to be installed on the rod. In doing so it was possible for the later downdraft carburetor and linkage to be utilized on your engine.
Because you have a later type of oil distributor, you will have to install the valve assembly and etc. in the correct order so that you will have oil pressure at your oil gauge.
If you post the engine block casting number and casting date, along with the manifold casting numbers and casting dates, we can verify that you do have a 1931 engine and we should be able to confirm what year the manifolds are on your engine as well.
To keep your car original you will have to locate the correct oil distributor, the correct Carter updraft carburetor, the correct updraft manifold assembly and the correct accelerator rod and pedal.
