Hello guys.
I could sure use some help. I made a cross member to support the TH350 transmission my son will be using in his '66 Chevy pickup. The cross member turned out great. My son, a Marine Corps aircraft mechanic turned mechanical engineer, then positioned the cross member and attempted to drill holes in the pickup frame web to bolt in the cross member.
The drill bits didn't even make a chip, just a very shallow crater, and we tried several drill bits. Apparently the pickup frame is not mild steel, but is some high strength material. I should have checked before making the cross member, but hindsight is always 20-20.
Any experience dealing with this will be appreciated. I have a home machine and welding shop and will return the favor to anyone who helps me. I'm the guy who successfully converted my '36 Chevy PU from 4.11 to 3.55 gears, so I'll try anything that has a chance of success.
Thanks!
Ray W raywaldbaum@gmail.com
