Dansker Offline OP
It's been a long time since I've been on this forum but that's mostly because I haven't had time to play with my car. With the day off today I decided to remedy that absence from the old girl. After filling up the tires I cranked the motor and amazingly it turned over and started the first crank. (Last time it was started was last November.). I idled the car for about 10 minutes and then I decided to take it for a short drive. It hasn't been on the road in nearly two years. The car ran for about 5 minutes driving down the road and then just lost power and died. If I would wait two or three minutes I could get the engine running for a minute or so but then it would die. I'm guessing a fuel problem. The car has a Stewart vacuum fuel system that has always seemed to work well. So I'm weighing digging into that vs an electrical issue. I still have the original type coil and so wondering if that could explain the engine running great for about 15 minutes and the dying but able to restart and run Afro a minute or so before dying. Where would you experts look first?
I would work on the fuel first. Disconnect the line from the carburetor as it enters. Place a cup or container under the line and turn on the fuel. See how much comes out before it is empty. Reconnect the line, start the engine and see how long it runs.
Second, check the spark. As soon as it dies, have someone turn the engine over and short a plug wire to ground. Nice bright blue spark? If no good spark, switch out the coil with a modern 6-volt unit.
One of those tests should identify either coil or vacuum tank.
Agrin devil
Dansker, when it won't start; pull a plug wire off and hold the end next to the engine block and have someone try to start it. You should have a blue spark jump to the engine block. If you have that then look at the fuel supply. Fuel bowl , filter if you have one etc. If no spark then you know your problem is electrical. Good luck.
Steve
Dansker Offline OP
Thanks Ray and Steve. I was thinking trying fuel issues first so that helped me make up my mind.
Dansker Offline OP
After experimenting today I think I'm going to install a modern coil. Since the wiring set up with the original coil and the new one is going to be a bit different I was wondering if someone could point me in the direction of some instructions. In particular I'm wondering how to wire the condenser.
The terminal (wire) on the condenser is connected to the wire going to the timer (distributor). The body of the condenser is connected to ground.
Agrin devil
Dansker Offline OP
Thanks Ray. My chief concern was getting a good ground since there's no mounting point on the distributor like there was in the good old new old days.
I'll play around.
Thanks again.
Terry
