Gus,
What has been advised above is right on. The picture is especially helpful. Or should be.
Since you have already removed the springs from the shoes to get to the wheel cylinders you are now to the part of separating the other stuff.
a. Take the pin and spring out by rotating the end of the pin. It sticks clean through the backing plate. This will allow the shoes to be removed as a unit, both front shoe and rear shoe.
b. After you get the shoes off, undertake removing the locking washer off the shoe links at the shoe by bending the locking washer flat enough that it will just that it will slip off the post when off center. There is an inside and outside to the links.
c. removal of the the stiff spring will rend the shoe. It and the lower pivot pin have the lock washers on the inside.
d. Notice how everything comes apart and reassemble in a like manner.
Good luck with it.
I hope you make it to Holtz. We need 41 there to offset the drab atmosphere created by 47/48 fleet liners! Do too!
Don't over think the shoes. They have to be assembled in a certain fashion and must be made in order that the shoes can be replaced without cussin too much.
Best,
Charlie
