Posts: 14 |
What is the correct brand (manufacturer) for headlight for my 1984 Cavalier? It has four headlights. Also, what is a source for the correct radiator cap? Thanks, John
John made a later post that I responed to. At the Middle West Meet I checked the sealed beams on a 1984 Monte and the POWER BEAM name was not on the lens. Just guide and sealed beam. I believe I also saw the same on your convertible.
Posts: 3,008 Likes: 1
Posts: 3,008 Likes: 1 |
The Power Beam bulbs in our 74 Nova have POWER BEAM in a circle in the center and GUIDE at the bottom of the lense.
Joined VCCA June 1, 1961
I believe the Power Beam was discontinued for the flat, square headlights.....that iis name on the glass.
Posts: 399 Likes: 1
Posts: 399 Likes: 1 |
Guys, it doesn't say powerbeam on the light itself, it just has GUIDE at the top. However they were called powerbeams and put out by AC/Delco in the 80s. Check my links to NOS lights
