Posts: 324 |
Did the 23-25 Superior Touring cars come from the factory with Belly Pans and if so does anyone know where to get a pattern?? Thanks, Tom
I can verify the 1925-28 as having engine splash pans. Not sure I have anything that will fit the 1923-24.
Posts: 324 |
Ray, If it fits a 25 it should fit a 24. Do you have one you would be willing to part with?
I'll run a search in the lean-to and see what years I have.
The one thing that jumped out at me was the third piece, the one that goes horizontal in front of the engine. I was unable to locate any of the early ones in this brief search. I will continue to look and if I find the sides I will contact you.
Posts: 129 Likes: 5
Posts: 129 Likes: 5 |
Try oldera.com.au he has them for sale new.
Posts: 305 |
The 1922, 1923 and 1924 cars did have a belly pan from the factory. Each year was different. I have an original 1922 unit, and friends have original 1923 and 1924 pieces. I was told that the difference in the 1923 and 24 units are due to the steering gearbox. I don’t know anything about the 1925 cars but Antique Radio is an expert.
Chris
Posts: 140 |
It looks to me like the 25/26 ones shown by Old Era.au may be Superior V style. The K is different because of the cast front chassis crossmember and the '24 would be closest to the K style. I am not sure the K and V had a third (front) part that Ray refers to, I've never seen one. I think I may have an original K set somewhere.
Regards Al
The horizontal pan is for the 1925 K R. The side pans are also for the 1925 K R, however their are two types the difference is in relation to the fastening to the engine attachment.
Posts: 324 |
Ray Thanks for taking the time to look and if you find something give me a jingle. My 24 is an early car and has the 23 front axle and steering box. It is an F series car so I know it is a 24. Thanks, Tom
Posts: 1,896 Likes: 28
Posts: 1,896 Likes: 28 |
My 24 roadster belly pan is all one piece.
Posts: 1,623 |
ALL Chevys had the pans well into the 30's, not sure when they quit.
My 1914 has a huge belly pan, all one piece, that runs from under the radiator all the way back to under the tranny. I can't remember what year the transition came when they stopped being a full pan under the whole front end, and started being separate pieces attaching at the sides of the engine, leaving the oil pan below the pans.
Yes, the '25 has a third front piece, under the radiator and in front of the engine. The other two being on either side of course. I believe those two attach to the oil pan screws, and then to the frame rails outboard.
They tended to get discarded of course, because they are a pain in the butt to take on and off.
Chevy Guru
Posts: 324 |
Dave, At your convenience could you take a photo or two of your pan? My email is in my profile. My folks live in MD, may have to swing by one day and take a peek at your car if you have the time. Tom
Posts: 324 |
Thanks Chevy Guru, By the time I am too old to walk I MAY know everything there is to know about this car! Thanks for the info!
Will do. I did loan it out a few years ago to gentlemen in the local region who made three for the missing club members 24's. I will ask him if he made patterns.
I am moving so it may take a few days.
