#343951 05/31/15 11:30 AM
What is the best alternative for the W-1? I want to keep an original look.
323window #343954 05/31/15 12:20 PM
Why do you want to try a replacement for a W-1? A Rochester B-1, later model Carters and I understand a downdraft Zenith were marketed as replacements for the original W-1s.
Other than small amount of fuel leakage past the throttle shaft which is not too hard to clean occasionally, the Carter W-1 carburetors run well and get reasonable gas mileage. That includes most of the alleged "worthless" early models. I routinely run a later '32 on my test engine and have a friend that runs a '33 on his '32 Cabriolet and wont' change to a 569s as it runs too good. I have supplied rebuilt '32 W-1 carburetors to several people and rebuilt a few more for others. So far all are satisfied enough they have not contacted me for rebuilds or replacements.
Chipper #343961 05/31/15 01:27 PM
JYD rebuilt my original 32 Carb and I works great and I use it for judged shows but run a later model for driving a lot. Chipper is right about the leaks through the throttle shaft but cleaning it up takes just a good wipe as you clean up the engine before a show etc. Since we drive ours so much, the later model idles a bit better but not to worry about it.
323window #343977 05/31/15 04:35 PM
Well ours has been rebuilt several times. It does idle good now, but is using a lot of gas. Seems to be little adjustment available. Some minor backfire when running 40+, black smoke out of exhaust pipe when first started.
323window #343979 05/31/15 05:04 PM
If the person rebuilding the carburetor does not have the specifications and coordinating adjustment gauge they can't do a first class rebuild. It is fairly common for alternate parts to be used on a rebuild. If they are not properly matched the carburetor will not run well. There are several W-1 castings that all look the same except to the experts.
323window #344006 05/31/15 09:25 PM
If I wanted an expert to rebuild my carb. Who is the best?
323window #344016 06/01/15 07:11 AM
Look to JYD or Chipper......I did...
Mac
1932Confederate #344021 06/01/15 08:46 AM
skip(junkyard dog) just got finished rebuilding my carb for my 30
rjh 08 s150
he did a great job the carb looks great and car my car runs great it never had so much power. he does a first class job and he was VERY understanding when it came to working with me.
i`m looking for a spare carb for him to do for me.
323window #344024 06/01/15 10:27 AM
Doyle Stokes has been rebuilding W-1 carburetors for an eon or two. I also work on them, though they are not my favorites. I prefer the updrafts. Last I knew Skipper wasn't doing W-1s any more. Maybe he has changed his mind? The Filling Station also has a rebuilding service for those carburetors.
Chipper #344029 06/01/15 12:09 PM
Correct.....I no longer do the W1 carburetors. I now only restore the 1929-31 Chevrolet Carter updraft carburetors.
Junkyard Dog #344104 06/02/15 09:25 AM
Chipper rebuilt my Carter W-1 for my '32 last winter. After approx. 200 miles, it performs great with good gas mileage (12-15 mpg). Of course, I have nothing to compare it to , being this is my first old Chevy, but I'm completely satisfied.
I believe it has a 569s metering rod and jet.
If it ain't brokeā€¦..fix it 'til it is.
hardaground #344106 06/02/15 09:39 AM
That is correct it has the original '32 W-1 body and most internals. A 569S metering rod and jet were installed instead of the '32 rod and jet. Not sure if it makes much difference as it is not possible to run both options side by side.
Chipper #344107 06/02/15 09:53 AM
With the original 32 W-1 carb I got about 10-12 MPG so I think the 569-S rod and jet are helping. I now have a 569-S carb on my 32 and get 15-19 MPG. I am not sure what rod and jet it has but think it is the correct one for the 569-S.
Chipper #344202 06/03/15 06:30 PM
Chipper,
About how much do you charge to due a rebuild? How long would it take? And do you guarantee satisfaction? Do you use the 569S metering rod and jet on all your rebuilds?
323window #344216 06/03/15 08:58 PM
I will send you a PM. I don't feel it is appropriate to discuss business on Chat.
Chipper #344293 06/05/15 12:13 AM
Got a carb for my 30 from Chipper, He's a good guy to deal with. My 30 runs good now.
Doc
1928 2dr Coach
1930 4dr Sedan
1930 3 window Coupe
1937 4dr Master Deluxe
1941 Special Deluxe
1946 Willys
1946 cj2a
1953 2dr 210
