Posts: 1,069 Likes: 9
Posts: 1,069 Likes: 9 |
The 48 manual calls for .040 plug gap. My 48 has a 52 216 rebuilt in it and calls for .035 gap. It has J8C Champions in it. What gap should I use?
Posts: 1,294 |
Either will work fine - I set mine at the .035"
Posts: 1,294 |
Either will work fine - I set mine at the .035" I always had set mine at 0.035 as called for. Kept hearing about 0.040 so I tried it. There was a noticeable difference, Especially at idle.
Posts: 1,884 Likes: 12
Posts: 1,884 Likes: 12 |
I agree. .040 seems to be a lot better. I've set mine at both.
Jon T.
For the 1937-1940 .040" was the recommended setting. If they were set closer you could get a surging at mid speeds. The little M-8 plugs used fro 1941-1948 were also set at .040" For 1949 and up .035" was recomended. Two reasons I would use the recomend .035"..... As the gaps widen from use you are closer to .035" and in a long run factory knows best for a reason.
Posts: 3,801 Likes: 1
Posts: 3,801 Likes: 1 |
The 48 manual calls for .040 plug gap. My 48 has a 52 216 rebuilt in it and calls for .035 gap. It has J8C Champions in it. What gap should I use? Do you prefer the Champions over the AC plugs ?
The Champions are the plug that were in it when I bought it. They looked great with no carbon build up at all. #6 had a minute white carbon around the outside edge. Don't have any idea how many miles are on the plugs.
Posts: 43 |
Shop manual says .040, then .040 it should be.
Skinnin' my knuckles on a daily basis.
Posts: 43 |
bobg, Your link takes you to the tune up specs beginning in 1949. In 1949, the spark plug gap is .035. Here is the link from the 42 - 47 shop manual where it states in the second sentence that the plug gap is .040: http://chevy.oldcarmanualproject.com/shop/1942_47/4247csm1229.htm
The engine in my 48 is a 52. That is where my original question came from.
Posts: 43 |
