#339876 04/11/15 11:47 AM
The 48 manual calls for .040 plug gap. My 48 has a 52 216 rebuilt in it and calls for .035 gap. It has J8C Champions in it. What gap should I use?
0.040 works best.
Either will work fine - I set mine at the .035"
Chev Nut #339882 04/11/15 12:20 PM
I always had set mine at 0.035 as called for. Kept hearing about 0.040 so I tried it. There was a noticeable difference, Especially at idle.
I agree. .040 seems to be a lot better. I've set mine at both.
Jon T.
Jonjet #339893 04/11/15 01:51 PM
For the 1937-1940 .040" was the recommended setting. If they were set closer you could get a surging at mid speeds.
The little M-8 plugs used fro 1941-1948 were also set at .040"
For 1949 and up .035" was recomended.
Two reasons I would use the recomend .035".....
As the gaps widen from use you are closer to .035" and in a long run factory knows best for a reason.
Do you prefer the Champions over the AC plugs ?
The Champions are the plug that were in it when I bought it.
They looked great with no carbon build up at all. #6 had a minute white carbon around the outside edge. Don't have any idea how many miles are on the plugs.
Shop manual says .040, then .040 it should be.
Skinnin' my knuckles on a daily basis.
TeeZee #343480 05/24/15 03:01 PM
bobg,
Your link takes you to the tune up specs beginning in 1949. In 1949, the spark plug gap is .035. Here is the link from the 42 - 47 shop manual where it states in the second sentence that the plug gap is .040:
http://chevy.oldcarmanualproject.com/shop/1942_47/4247csm1229.htm
TeeZee #343963 05/31/15 01:48 PM
The engine in my 48 is a 52. That is where my original question came from.
Whoops! Sorry!
