Posts: 30 |
Gents: under the dash, after removing the radio for service, I found a loose orange wire. It has a v-shaped shiny clip on the end of it, and it's about 8 to 10 inches long, so it goes somewhere in the area of the radio. Anyone know what it might be? I did notice the glove box light switch does not have a wire going to it: is this it? I have never seen an electrical connector like this.
Posts: 865 |
It sounds like the glove box wire, the V shaped wire plugs into the combination glove box switch-light. It is usually hot.
I did notice the glove box light switch does not have a wire going to it: is this it? If the connector fits onto the glove box light switch then that is where the wire goes.
Posts: 30 |
The above replies are logical. What is the correct bulb for the glovebox lamp? There was a bulb in it but it was not right: it was just stuck in and fell right out. the switch looks new. This is a friend's car and it is almost perfect: a retired fireman restored it and it is just like working on a new car. Underneath the dash, looking up, is amazing: it is literally brand new.
Glove box #53 or #57 bulb. Socket ends the same for either one.
Posts: 399 Likes: 1
Posts: 399 Likes: 1 |
Might be stop switch or flasher with the V shaped connection.
