I am in my final stages of preparing my body parts for painting. This winter I used Black Diamond Media Blasting Material to blast the fenders, doors, and hoods. I used the fine 30/60 blend. The product is made of recycled materials, mostly coal slag. It leaves a slight tooth finish to the metal which I assume is good for doing body work on and a satisfactory paint surface for using sealers and primers?
I now want to blast the body. A local body shop, I may use to paint the car, is recommending I use walnut shell media for blasting. They are concerned with the potential for warping, and note that the metal surface will be smooth, and metal prep for painting will be minimal.
Has anyone used walnut shell media with good results? I do not have a lot of rust issues and the remaining paint on the car is worn thin? Why should I worry about warping when I had non when I did my other parts? Perhaps, if I am worried about the roof warping I should just use walnut shells there?
Thanks, Mike
![[Linked Image from i1321.photobucket.com]](http://i1321.photobucket.com/albums/u560/41chevymike/IMG_3076_zps6zw2ktnw.jpg)
