Posts: 53 |
I am looking for a coil bracket for my coil. My coil died and the bracket was spot welded to the coil.
I have purchased two one from a private party and the other from NAPA, neither was correct.
Help.
Posts: 3,292 |
If your looking for 1940 parts ID you should be posting in the 1937 & up section not this one 33-36
mike
Posts: 654 Likes: 3
Posts: 654 Likes: 3 |
Can you not just break the weld and use your old bracket?
J Franklin
Posts: 822 |
There's on on ebay right now for $3.99.
Ray W
Even the GM Delco coil did not come with a bracket. The coil was more or less a universal and was necessary to buy a bracket to mount the coil.
