#343276 05/21/15 04:17 PM
Hello
In the UK we are having more ethanol added to the gas on our forecourts.
We have 95 octane unleaded as the standard.
I am running my 23 roadster on the normal unleaded, but wonder if i should be adding a lead substitute with octane booster?
23Chevvy #343281 05/21/15 06:13 PM
Not necessary....There was no lead in regular grades util after WWII.....and was not even "invented" in 1923.
23Chevvy #343283 05/21/15 06:50 PM
No need for octane boost. The lowest grade gas today is far better than any gasoline available in the 1920's.
Steve
SSG26K #343295 05/21/15 09:41 PM
I agree. Stay away from fuel additives....you don't need them.
What do you guys think of a pint of Diesel in a 10 gal tank of gas. I think I like to think it's for lubrication
Happiness is the trip, not the destination.
Terry28 #343310 05/22/15 12:18 AM
Hi Terry,
The lowest octane we get over here is 91.
For the last 4 years I have been running I Liter of diesel per full tank on my 28 Chev.
Its a cheap upper cylinder lubricant, and more importantly it lowers the temperature in the combustion chamber as I use the long reach 3077's.
No smoking, no ill effects.
Cheers
Ray
Well thanks Ray...I use, I think W89D's is the right order, and haven't noticed any smell or smoke,and it behaves and starts on the second pull of the crank, usually. wink
Terry28 #343356 05/22/15 03:57 PM
W89D is the Champion crossover for the 3077. I will be running them in my 1914 shortly. The old AC Titans will just be for show days.
Chevy Guru
SSG26K #343357 05/22/15 03:58 PM
That is good enough for me.
I will carry on using the unleaded.
Thanks for the replies.
steve
23Chevvy #343358 05/22/15 04:00 PM
I believe UK and US use different formulas to calculate octane.
Chevy Guru
W89D's have worked very well and if your 1914 can handle the reach on the plugs I would use them until it comes time to show off. The titans are likely to hard to come by to use them all the time. wink....Terry
95 RON (Europe and much of the world) is about equal to 87 MON (USA).
Regards
Al
AlBrass #343406 05/23/15 08:52 AM
The old 4 cylinder engiines can use 50 octane.
