#34322 01/07/03 11:32 PM
I have just purchased the delivery, with 67k original miles, complete and never abused. radio and heat delete. But I need a lead on nos replacements for the rubber rock guards that are mounted just in front of the rear wheels. Mine have died under the arizona sun. any suggestions?
#34323 01/08/03 12:05 AM
Prof. I don't know if the rock guards are interchangeable for sedan and sedan delivery or not, but try this link to National Chevy Association, they specialize in those years,and they also have some used parts and parts cars.
http://www.nationalchevyassoc.com/index.cfm/1
You can email them your questions too.
#34324 01/08/03 07:09 PM
Prof.,The rubber stone shields used on the sedan delivery are the same as what is used on a 150 series 2 door.This will widen your scope for the search.Most body trim on a sedan delivery are shared with the 150.For future reference the sdl. is a passenger car and shares all mechanical parts with a car.The 1953 is one exception.In 1953 all stick shift cars used the 235 engine -this was the "old" 235 with cast iron pistons and connecting rod dippers for oiling.The '53 sedan del. was provided with the 1952 216 engine.This is identified by the tall engine side cover that goes up and meets the valve cover.If your car has the original 216 most engine parts will be different tnan a 235.This will include the distributor,carburetor,and most engine parts as well as exhaust.It also retains the 1952 4.11 gear ratio where as the cars had a 3.70 ratio.
#34325 01/08/03 07:17 PM
Mr. Mack thanks for the reply, I have tried to find out with national but no reply as of yet. I did notice that most all "normal" passanger cars in the '53 year, the gravel guards are in stainless, rather than rubber....while I would like to keep in completely original, if necessary I could change to metal. Any leads on whom might have such a classic stainless just sitting in their garage taken up space?
#34326 01/08/03 07:22 PM
Chevgene:
thanks for the info, it is all original...
bone stock, never painted or anything. Seems to have the 216, with three on the tree. Any leads for the rock guards, and I would be forever in your debt. Tried to take mine off and now I have a pile of blace crud on the floor of the garage.
Everywhere I have checked, no go... wonder if someone has a nos set just sittin......
pat
#34327 01/08/03 08:50 PM
I have seen the black rubber stone guards for bidding on ebay in the past.....go to www.ebay.com , home and do a search on 1953 chevrolet and see if any are for sale.
#34328 01/21/03 10:50 AM
Thanks for everyones help, I have found a set on e-bay and hope to be the successful bidder. Wish me luck.
#34329 01/22/03 01:02 AM
I got um, nos pair for $90.00, now anybody have some nos headlight benzels?
#34330 01/22/03 12:13 PM
If they are the same as the 54 belair/210 series I have accumulated oodles. Greg 54hdt dance
#34331 02/01/03 08:50 PM
Greg: they will fit, but are slightly different.
I will continue to look for 53, but I do need a passanger side sun visor if you happen to have one
