What holds the connecting linkage for the windshield wipers onto the vacuum motor ? Right now they are just laying over the studs. Should there be a " C " clip or a " hairpin " clip over / around the stud ?
There is 2 oval shaped clips with a spring to pull them together so they can't come off. I used c-clips.
Thanks I will crawl under there and measure the diameter and pick up a couple of clips.
