I have recently acquired a '32 Chevy Confederate from my father-in-law. Getting it drivable so I can sell it. The cylinder head is cracked so I am looking to purchase one somewhere...casting #836718.
Can anyone point me to where I can acquire one?
Thanks,
Joe Elliott
Good luck finding one and make sure you bring a thick wallet. If you find one, make sure the seller has had it magnafluxed to check for cracks.
1932 5 Window Confederate Coupe Best of Era 6 cylinder 2016
1968 Corvette Roadster 383 CI-425 HP
1938 Business Coupe "personalized"
Hi there and welcome to Chevy Chatter.
Good luck in finding a 1932 head that is not cracked. Those things are more rare than a chicken with false teeth. If your head is repairable you might want to go that route instead.
Joe, I saved some cracked cylinder heads. Chipper convinced me to not junk them, that sooner or later I would find someone that could repair the cracks. The first two of these, 1931 & 1933 heads are now repaired by a shop in Mesa, Arizona. I will pick them up next Tuesday. The 1933 engine should be running in a few days. If there are no problems, one of the next two heads going to AZ for inspection and repair is a 1932 head. If that 1932 head is ok it will be for sale. Or you could call the machine shop:
Bailey's Machine & Engine Parts
727 N. Country Club Dr.
Mesa, AZ 85201
480 962-9756
If you have old Chevrolets, other old Chevrolets will find out where you live.
