hello
new to forum and was wondering two things
1 - does anyone have info on the rear axle removal procedure (lots of up/down play on the axle) and I assume its the rear wheel bearing and seal that is done
2- does anyone have a PDF of the master shop catalogue or parts list for this era of truck (its a AM with 4 speed tranny) im having problems getting proper part numbers for the various components I will require
thank you all in advance and look forward to the restoration
