Posts: 172 |
Does anyone know what Bulb is used on the 48 fog lights? Got a set without the bulbs.
From the information in the parts book If they are the real small 4 5/8" lens Guide brand. Some had sealed beams. Other posibilties are if the base of the bulb has the flange with three holes it could be a 1323 or 1007 bulb - both are 32 candle power. If the bulb does not have the flange (like a tail lamp bulb style) it is a 1133 which is also a 32 CP.
Posts: 172 |
Posts: 172 |
was able to find these blubs here http://www.bulbtown.com/Thanks
Posts: 3 |
Anyone have any 1948 foglight brackets for sale?
Posts: 3,578 |
I think I have some NORS units you would have to but the lights as well???Never used
Posts: 146 |
Hello are the 1946 fog lights the same as the 1948?
The lamps are the same but the brackets are cast in 1946 and stamped in 1948.
