I was driving my 1941 Chevrolet Master Deluxe, 216 inline six, totally original. The throttle cable from dash to carb broke causing the engine to go to extremely high R.P.M. I nursed the car back home, being nearly impossible to drive, due to being at high idle. A few months back, I replaced the carb and was able to connect the throttle cable, no problem. But this time, since the connection to the carb is completely missing, I have nothing to go from since I forgot how the old connection gets attatcched. I did run the cable through the hole in the accelerator shaft and placed a brass fitting with the 3/32 screw in it, but I don't feel it is the proper way because the idle is still sky high.
