Rich33 Offline OP
I did a search for this but couldn't find. I just wanted to make sure the following is correct. There is no rubber seal between grill and headlight bar and headlight bar to fender. It was more like a tar paper. Is this correct?
Is the the same with rear taillights to fenders?
Rich33
1933 5 Window Chevy Master Coupe
1951 1500 Chevy Truck 5 Window
1968 Chevy Camaro
If I remember correctly the parts catalog calls for a gasket between the fender & the bar but not the other end & it shows a gasket for the tail light arm to fender. It would've been a felt material like roofing felt. I need to double check my notes when I get home...Joe
1931 Sedan Delivery 31570
1968 Z/28 Camaro
1969 SS 396 Camaro
If you have a LYNN STEELE rubber parts catalogue .
I KNOW HE MAKES A SPECIAL RUBBER MOLDED GASKET THAT GOES BETWEEN THE HEADLIGHT BAR TOOOOO THE RADSHELL > Just have to search all his offering in the Chevrolet section. He makes them for my 34-35 standards.
mike lynch........... Agrin
Those are street rod design. They're incorrect for restorations...Joe
1968 Z/28 Camaro
1969 SS 396 Camaro
There is a ground path for the lights through that area? If I remember correctly?
