Oliver Offline OP
Chevy Engine original. Powerglide two speed original. original Carb & distrib. rebuilt, new points and plugs, timing done using flywheel markings. 71,000 orig miles. Vac. advance for this eng. turns entire distrib. and slows firing when vac falls during 0-10 mph acceleration. We are pretty stumped. Car drives great after 10 mph and can accelerate quickly after 10 mph. Anybody out there solved this before??
Hesitating in Louisiana
Most likely: accelerator pump or circuit stopped up. With engine OFF :o remove air cleaner/filter, take a look with a light down the throat of the carb, move the accelerator quickly and you should see raw gas injected into the throat. :rolleyes:
I agree with the previous post, I seem to recall a small screen in the bottom of the acclerator pump area may be this is clogged. :confused:
Oliver Offline OP
Thanks guys. I will check it out as soon as this family reunion thing at my house is over. Will update next week.
Pax Oliver
need the routing of the heater hoses to engine,should have wrote it down!
which way do the heater hoses run?
Thermostat housing to bottom connection of heater
Water pump to top heater connection
Joined VCCA June 1, 1961
Just curious if you have resolved your accelleration problem.
