http://1931chevrolet.com/articles/steering/index.htmIf you put "steering" in a search you will see several threads on your topic just in the last 6 months.
Steering sector seal Chipper put this in one of the threads.If you are rebuilding your steering box this may be a good thing to do.
The following written by Doug Bell was published in the G&D about 50 years ago.
Anyone interested in modifying a 1929-1932 Chevrolet steering box so that it will hold gear oil? There is no sector shaft seal, so grease has to be used as the lubricant, in order that it will not run out. Here is an easy fix. Buy National Seal No. 240731, remove the sector shaft housing, mount on a lathe using a 1 inch mandrel which is held in a chuck and counter bore the outside end of the housing approx. 5/32” deep and about 0.004-0.006” smaller in diameter than outside of the seal (the sector shaft bushing may have to be pressed into the housing 1/8" approx.). I have made this change to my1931 and it now holds # 80 steering gear lube without leaking a drop. It sure makes a difference when it gets cold up here.
